drive shaft help
Discussion in 'The Garage' started by adamforsythe, Mar 31, 2005.
  1. adamforsythe
    adamforsythe 1/2 ton status
    Oct 16, 2004
    1,394
    Maine
    Hello,
    I am going to be buying new shafts for my k5 blazer what should my custom shafts be built with?
    Composite, Aluminum, Hybrid, Steel
    Adam
  2. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    Hello,
    What is the length of the back and front shafts for a 1985 K5 Blazer with a stock rear end no lift and a th350-np205 combo?
    Adam
  3. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    I think most of the alternative materials are made mostly for racing applications, to cut down on weight. I would just go with steel.
  4. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    Hello,
    Thats kinda what I was thinking.
    Adam
  5. dyeager535
    26,979
    My understanding of driveshaft making is that you need to get u-joints at both ends (unless your 205 is a slip yoke, then I have NO clue) and measure from the center of each cap. The driveline shop then figures all the rest out.
    It is MUCH cheaper to go to the driveline shop with pieces they can use, at least half price around here. Need yoke(s) and the slip section if not a slip yoke t-case.
    As to material, there is nothing inherently wrong with AL or carbon fiber shafts, both have been used in stock and non-stock applications with no problem. However, I would be pretty leery of the aluminum if I had ANY potential of hitting it with anything like a rock or tree. Thin steel probably isn't much better for impact, it doesn't take much to weaken a shaft, but it would still be better than aluminum. As a for instance, I don't believe any of the light duty trucks (at least) ever used an aluminum shaft, but I've seen carbon fiber. Probably extremely expensive to have either made, compared to steel.
