drive shaft leanghts
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by darkshadow, Dec 31, 2005.
  1. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    wondering if you can tell me the aproxomet differance, between
    driveshafts for
    a 88 3/4 suburban 350/400/208 and
    6.2/465/205.
    thanks guys
  2. Jishory
    Jishory 1/2 ton status
    Jan 8, 2002
    1,367
    Palmdale, CA
    not sure if the engine length makes a difference, i would assume it would be the same based on transmission crossmembers with the same drivetrain/diff engine. the sm465 is 12 inches long so you would need to equate the bellhousing into the equation but according to the novak website the th400 would be 17.9 inches equivalent when factoring in the bellhousing for a manual transmission(not sure which manual transmission) but 24.37 inches overall. the np205 and 208 are the same lengths. when i swapped my 700r4/208 for a sm465/205 it ended up shorter...
    http://www.novak-adapt.com/knowledge/transmission_gateway.htm
    http://www.off-road.com/chevy/tech/transfercaseguide/
  3. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    its just a few inches. the onyl differacne is the tranny/ tcase. i have a 400/208 in my long bed and am going to be swapping in a 465/205. i think its 2-3 inches longer for the 465/ 205. For the 400/ 208 i measured to the tip of the slip yoke on the t case.
  4. dleroy43
    dleroy43 1/2 ton status GMOTM Winner
    Jul 22, 2002
    1,517
    Martinsburg WV
    I have 465 and 241 burb,
    55" to rear tcase seal + 4-5 to for the sye I dont have. then whatver the diff is between 205 and 241
