drive shaft length
Discussion in 'The Garage' started by jones, May 19, 2004.
  1. jones
    jones 1/2 ton status
    May 17, 2004
    379
    IONIA,MI USA
    going from 700r4/208 to 400/208,what is the difference in shaft length?anyone?anyone?also,whats a good gear ratio for running 31's(stock height)in anticipation of getting bit by the BIG TRUCK BUG in which case 6"and 35's max?oh!84 lwb
  2. bigbadchev84
    bigbadchev84 1/2 ton status
    May 17, 2004
    2,191
    Hermiston, Oregon
    i just did the same thing, the 400 is about 1" longer with the transfer case
  3. jones
    May 17, 2004
    379
    IONIA,MI USA
    so, have shaft lengthened or,hey i forgot.girlfriends mom got pissed at her husband and gave his '76 3/4t. to me.it has a th350/?.i'm guessing a 203.L-L LOC-N-H-H LOC.Also has locking hubs.will that shaft work?
  4. bigbadchev84
    May 17, 2004
    2,191
    Hermiston, Oregon
    he needs a driveline from a 208 transfer case the slip yoke goes into the t-case, not built into the driveline like the 203 or 205
  5. jones
    May 17, 2004
    379
    IONIA,MI USA
    WHAT DO YOU MEAN?THE 400 HAS AN ADAPTER BETWEEN IT AND THE T-CASE.DUDE SAID THE ADAPTER ALONE COST NEARLY $700.ANYWAY...DRIVELINE???
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    This man is correct. He's referring to the fact that you need a different style rear driveshaft to run a 208 transfer case instead of a 203.
    A transfer case adapter doesn't cost $700, that's insane. Hell, Watson's doubler adapter isn't even that expensive I don't think.
  7. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    You Can't determine how long a driveshaft you are going to need before you change parts, by looking at other parts. Two trucks with a 350/700/208/10b will have 2 different front driveshaft lengths. The correct way to do this is do you tranny swap then see if your stock shafts work if not have them lengthened or shortened accordingly.
  8. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    The adaptor is $437.12 from AA to replace a 700 with a 400 not sure if that comes with a replacement input gear or not. The 400 version 208 is a 32 spline the 700 version is 27 spline. Probably easier to look around for a 400/208 combo with the adaptor used. /forums/images/graemlins/peace.gif
  9. jones
    May 17, 2004
    379
    IONIA,MI USA
    thanks for the input,guys.the 400/208 combo i've got has an adapter.however,there's a problem.upon taking the tranny to the shop tp have it checked out,they pionted out to me that the adapter(4"thick)wasn't allowing full insertion of the trans. output shaft(2.25"length as opposed to 1")into the input on the t-case.the adapter is approx. 2"to thick as it is allowing only .25"-.5" of the trans. shaft into the t-case resulting in nearly sheared splines on the trans. shaft.and that,my friends,sucks a$$! i somewhat expected problems,though,which is why i told the dude i wanted to have it inspected before i bought it.so...now it's free. /forums/images/graemlins/grin.gifwhat i need is 1)a 2" adapter or 2)a longer output shaft for the trans.but with my luck,i'm probably screwed on both accounts since i have way to many attorney fees and not enough x-tra cash for the $400+ kit from AA.is there a used one floatin' around out there somewhere? /forums/images/graemlins/1zhelp.gif
