drive shaft length
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by arq, Sep 11, 2001.
  1. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    anyone know what the length of the stock drive shaft is?? I need the length of the TUBE only not the part that retracts, from weld to weld.
    Also, does the drive shaft need to be shorten or lengthen when i put in a 4" lift. I'll probably do a shackle flip.
    thanks,
    ARQ
    1-72 4x4 CST Blazer
    2-71 4x4 CST Blazer
  2. dr1553
    dr1553 Registered Member
    Nov 4, 2000
    90
    Lake Jackson, Texas
    Hola,
    Front 14 1/4"
    Rear 26 1/4"
    This is on my 1972 K5 Blazer.
    I dont know about the lift....I would guess you would have to extend them because you are going to get more droop.
    Later,
    David
