Drive shaft/Lift/14 bolt FF Questions NEED HELP
Discussion in 'The Garage' started by Rob 85K5, Mar 12, 2002.
  1. Rob 85K5
    Rob 85K5 1/2 ton status GMOTM Winner
    1,487
    Pensacola, Florida
    I grenaded my 10 last weekend and have a 14FF to install.
    I have 2.5" of lift and need to know if the shaft is going to work. I have read where it works for a 4" lift w/o problems, but the last thing I need to do is break the t-case with the drive shaft being too long.
    The reason I ask is that I will more than likely end up with 4" in the future, and don't want to re-work the shaft.
  2. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Probably the only way to know for sure if it will work is to install everything and check it.
  3. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    you are going to need a specialty ujoint for the rear of your rear driveshaft. i bleive you would need napa # 348, that is if it uses the external clips. there is another specialty ujoint for the internal clips, but maybe someone else can help you with that number since i cant seem to remember
  4. bigmack
    bigmack 1/2 ton status
    Jan 3, 2002
    478
    Tennessee
    I just wanted to say that you will love that 14 bolt, I dont know about your driveshaft with the 2.5" lift, but mine worked out fine with my 4" lift (as you allready knew). Good Luck
  5. Zepplin
    Zepplin 1/2 ton status
    Aug 29, 2000
    920
    Bay City, MI 48706
