drive shaft on exhaust
Discussion in 'The Garage' started by '89 bucket, May 2, 2005.
  1. '89 bucket
    '89 bucket Registered Member
    Feb 22, 2005
    25
    delanco N.J.
    i installed a 4" lift on my truck and the kit suggest droping the transfer case down,
    i noticed that the front drive shaft is already closer than i would like to the cross piece to the exhaust
    if i go any lower i will surely have to modify the exhause crossover
    has anyone ever had this problem??
    also, in the installation of the lift there were a few parts that i had to cut off or that were lost,,,, nuts and bolts,,,, where can i get replacements for these??
    HELP!
  2. Joshinator
    Joshinator Registered Member
    Jan 19, 2005
    58
    Sulphur Louisiana
    Most common nuts and bolts can be replaced at your local hardware store. My local Lowes store has a huge selection of all sorts of fasteners in different grades.
  3. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    I don't think there's any reason to drop the transfer case down for only a 4" lift. You probably can just leave it, might not even have to mess with your drivelines. I didn't.
  4. Joshinator
    Jan 19, 2005
    58
    Sulphur Louisiana
    He made a good point, in fact, i have about 4" of lift and i have my T-case raised up higher than the factory location with no noticable driveline vibes.
  5. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,005
    838
    Pinckney, MI
    4" you shouldn't worry about droping the t case. But with a 6 I had to. As for the exhaust I had the y pipe routed arround the d shaft for a temporary fix. Headers and true duals will fix that.
