Drive shaft opinions
Discussion in 'The Garage' started by BigCountryx, Jul 17, 2005.
  1. BigCountryx
    BigCountryx 1/2 ton status
    Feb 19, 2005
    519
    Gonzales, LA
    I've got a DIY4x4 Flip & Switch kit. (very nice btw) I've got the 6" shackles which should net about 5" of rear lift. I have ORD zero rates to relocate the axle, but I may not use it at first. I figure it's gonna take some tweaking before I've got the setup I'm planning to run. eventually I plan on HAD shaft and an SYE for my 241 but my funds are depleating rapidly (don't have an extra 800 buck laying around). Do ya'll think that I could run the stock shaft for a while w/o too much trouble? I'll need a conversion joint to make up to the 14ff, and hopefully I'll be OK 'till I decide exactly what to do. I've got 6" TC front springs on a D60 so I will likely have a severe saggy butt for a while, but that will be taken care of in due time. If I can get away with the stock shaft till my front spring settle, then I can determine how much lift I need to add to the rear to level it out and then do my permenant rear driveline work. Am I asking too much, or is this possible?
    Sorry for the rambling :crazy:
    Another thing is I have to reweld my rear perches. If I keep my rear shaft for a while, I'll have to run a way different pinion angle than with the 1 ton cv that HAD recomends. Would it be OK to make a minimal single pass weld to hold the perches in the desired position for the time being? Might make it easier when the time comes to roll them again.
  2. BigCountryx
    Feb 19, 2005
    519
    Gonzales, LA
    bump ttt
  3. K5Chris
    K5Chris 1/2 ton status
    Mar 11, 2002
    805
    New Orleans, LA
    i'm temporarily running my stock shaft with ~ 7" rear lift. it does alright with the tcase lowered. its a temporary setup, and it works, but i wouldnt trust it offroad.
    you could always run a tapered zero rate instead of rewelding your perches.
  4. BigCountryx
    Feb 19, 2005
    519
    Gonzales, LA
    Thanks, just needed the confirmation that someone had run this before. I don't intend to wheel it this way, I just need as little down time as possible.
