Drive Shaft Options
Discussion in 'The Garage' started by BigCountryx, Aug 2, 2005.
  1. BigCountryx
    BigCountryx 1/2 ton status
    Feb 19, 2005
    519
    Gonzales, LA
    What model trucks came with 1 piece rear driveshafts that had a rear 1350 u-joint and a front slip yoke for a np241? I'm thinking that 88+ 3/4ton and 1ton 4wd regcab and ex-cabs probably could fit this bill (Newer body style of course). Am I right?
    If I find one cheap I'm thinking I could shorten it and keep it for a trail spare or have it modded to make a cv shaft for the Blaz. What y'all think?
  2. BigCountryx
    Feb 19, 2005
    519
    Gonzales, LA
    ttt, someone's got to know this.
  3. sweetk30
    Nov 1, 2004
    25,548
    543
    horseheads , ny 14845
    most if not all 88-up are aluminum shaft. and 14 sf rear up is 1350 for sure. not sure on 10 bolt.
  4. BigCountryx
    Feb 19, 2005
    519
    Gonzales, LA
    So the 1350 will work, how about the slip yoke for the np241 tail? Are they all the same spline or did they change?
  5. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    I am curious about this as well. I do know that some stock Blazers through out the 80's IIRC that had a 465 in them came with 1350's in the rear driveline at the slip yoke and axle yoke. Mine did......
  6. Jimbo*
    Jimbo* 1/2 ton status
    Mar 8, 2005
    1,420
    roswell, new mexico
    My 88 GMC 3/4 4x4 sub had the setup you are looking for. 350/400/208
    slip yoke to 14SF with 1350 u-joints at both ends. Not sure, but I don't think the M1008 had a two piece shaft, so there might be a source for you.
    Jimbo
