drive shaft out of wack!!!!
Discussion in 'The Garage' started by CRAZEDHICK3, Aug 7, 2002.
  1. CRAZEDHICK3
    CRAZEDHICK3 Registered Member
    Feb 14, 2002
    6
    Virginia
    Just installed 6"lift(all springs)on my 90 Jimmy. getting a bad vibration 25mph-45mph. Looking at the back of the truck to the drive shaft, i can see that the shaft goes at an angle to the left to the transfer case. Is this right? If not, how do I fix??? Thanx
  2. jc71355
    jc71355 1/2 ton status
    Jan 13, 2002
    830
    Port Neches, Texas
    You mean the T-case and Axle are not exatly inline and the shaft doesn't go exactly perpendicular to the axle? If you just changed springs that shouldn't be the problem. I don't think that they are exactly inline. I would think that your pinion needs to be turned up with shims if you haven't done this. You probobly also need to drop your T-case or get a C/V style drive shaft to correct the angle. Hope this helps.
    James
  3. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    Reading driveshaft tech articles.
    "In order for a two u-joint driveline to be free of vibration it must be in balance, and the angle of the front u-joint must be the same as, or very close to, the angle of the rear u-joint. If there is a noticeable difference in the angles there will be a vibration."
    - Randy's Ring and Pinion
    found
    http://www.4x4now.com/gt0899.htm
    Also check out www.4xshaft.com click on TECH INFO.
    A two piece (as in our rear driveshafts) should be parrallel.
    A CV type driveshaft (as in our fronts) should indeed have the pinion pointing up.
  4. jc71355
    Jan 13, 2002
    830
    Port Neches, Texas
    Sorry I'm confused. I don't know if he meant the outputs where not in line or if the shaft was bent. I'm just confused /forums/images/icons/crazy.gif .
  5. TopOff
    Jan 16, 2002
    1,760
    Folsom, ca
    Hmmm, maybe...
    My rear axle is not straight to my transfer ....looking from rear to front. Maybe that's what he means.
  6. drivelineman
    drivelineman 1/2 ton status
    Aug 23, 2000
    707
    you have an angle problem - you need a c/v to fix it- Jess
  7. Chaz88K5
    Chaz88K5 1/2 ton status
    2,979
    Stockton/Lodi CA
    you might get way without runnin a C/V shaft...just play with the angles on the rear joint by adding shims...and since you have a 90 you can get a SYE kit...and get rid of the slip yoke all together /forums/images/icons/grin.gif if all else fails then go for the C/V..
