drive shaft question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 88bblazen, May 5, 2004.
  1. 88bblazen
    88bblazen Registered Member
    Mar 23, 2004
    32
    SouthTexas
    if i have a 4" lift and 35's put on my 88 blazer will i have any problems with the rear drive shaft or any other problems /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    It depends on what type of lift ( blocks , springs, or flip ) . Other factors include offset zero rates . In my case( flip with 2 wd axle ) it fit lengthwise , but had vibrations. I suspect it won't be so bad if you use lift blocks /forums/images/graemlins/k5.gif
  3. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    Just like pauly said. What kind of lift do you plan on running?
    -Harrison
  4. 88bblazen
    Mar 23, 2004
    32
    SouthTexas
    i plan on running leaf springs all around /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    It will probably be fine then.
  6. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    You might need to shim the pinion up a little or lower the tcase some or both. The actual length should be ok.
    Harley
  7. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    The lifted rear leaf springs *should have the proper shims installed if the lift calls for them. I know my 4" Rough Country system had shims installed on the rear packs.
    And FYI, I didn't lower my t-case, but I've also got a 'burban (ie, much longer driveshaft).
  8. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Ya, it is all dependent on your lift you buy. Each truck will be a little different. Some may need a slight tcase drop some may not.
    The lift companies also can only generalize what your setup may be too. They can only account for stock trucks which as you know most of us don't run. That is why I say you may need to shim it and or drop the tcase.
    There were also alot of different trans/tcase combo's available throughout the years. The lift companies have to generalize and ball park things because of the different drivetrain lengths. Also you have to think the same springs are used for K5's, K10's (short and longbed), and K20's. Each driveshaft is totally different length and may need different shims or drop amounts.
    Harley
  9. heavy4x4
    Aug 28, 2002
    3,270
    I didn't think I was disagreeing with you. /forums/images/graemlins/thinking.gif /forums/images/graemlins/dunno.gif /forums/images/graemlins/wink.gif
  10. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Your not, I am just expounding on why what the manufactures put in may not work 100% of the time. Each truck will be different. I am just letting the question asker know why he may get vibs even though the lift company has already tried to account for the lift with a shim.
    Sorry if I sound like I was disagreeing with you. I didn't mean too.
    Harley
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Hell even if you were talking about the same truck, there are variables that can change things. I've seen two identical rigs and one has a 2 piece shaft and the other will have a 1 piece. Same wb, same trans/case etc.
  12. puck k5
    puck k5 Registered Member
    Apr 18, 2004
    74
    Pennsylvania
    I installed a 4inch BDS lift . 4 new springs front and back. i am running 35`s also.Had the lift for a month no problems with the driveshaft at all.
  13. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    I just installed a 4" TC all spring lift with 1" zero-rates in the rear. No vibes - up to 75 on the highway. The front u-joint looks like its almost at its max angle though. I also installed a 14BFF in the rear with added a tiny bit of length in the pinion, in effect shortening the required driveshaft length. There were NO shims with the springs, and they were bought as a kit through ORD.
