drive shaft questions?
Discussion in 'The Garage' started by k5 krawler 50, May 20, 2004.
  1. k5 krawler 50
    k5 krawler 50 1/2 ton status
    Jan 26, 2004
    1,467
    Gardnerville, NV
    Hey i am getting ready to install my 6 inch lift, how many of you guys had your drive shafts lengthened and how much longer is it now, and roughly how much did it cost you? Thanks.
    Cory.
  2. offroad87
    offroad87 Registered Member
    Feb 2, 2004
    57
    Atoka, TN
    i have a 6 inch on mine, i got it lenghthened but i still couldt get the angles right so i just went with a cv driveshaft. oh just to get it lenthened around 90-120 bucks. cv driveshaft 340 after shipping if you get the elcheapo like i did.
  3. bigbadchev84
    bigbadchev84 1/2 ton status
    May 17, 2004
    2,191
    Hermiston, Oregon
    The driveline shop here charges $35 plus u-joints to shorten drive shafts, it is cheaper to shorten than lengthen, if i were you i would find one out of a short or longbox /forums/images/graemlins/thumb.gif
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    find one that is too long and have it cut down, its easy to find longer shafts, make sure diameter of ends of donor shaft are the same though as your yokes youre using
  5. k5 krawler 50
    Jan 26, 2004
    1,467
    Gardnerville, NV
    I have some 7 degree shims.. they might be a little different the 7 but i think thats what they are, so you think if i use those or get some others that will help, cuz i already planed on the lengthen, and wish i would have already thought of the shortening method first. Well what do u think about the shims and the lengthening? Thanks for your help.
    Cory.
