drive shaft questions
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by wfahlgren, Feb 6, 2001.
  1. wfahlgren
    wfahlgren 1/2 ton status
    Dec 30, 2000
    157
    Northern California
    Do I need to get new or legnthed drive shafts for a 4 inch suspention and a 3 inch body lift, for a 72 blazer. How about just the susp lift?
  2. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    I think it really depends... I put on a 4 inch susp lift on my 78 and I had my driveshaft literally fall out 2 times... when I lock up the rear brakes the body flexed enough to make it happen... So you may have to... not everyone has had to... I am addin gmy 3 inch body lift saturday and it shouldnt make a difference in the angles.. it ha nothing to do with the drivelines (the body lift)
    SO... You may need to./.. if you do the lift and can see the splines on the rear one... you better do it.. or your asking for trouble... mine had 1/2 inch showin of the spline... I had the shaft lengthened 1.75 inches...
    Cost me 140... Installed and painted...
    Um... yes officer I know it's too big...
