Drive Shaft to Transmission pan clearance???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by keith, Apr 28, 2000.
  1. keith
    keith 1/2 ton status
    1,158
    La Fayette, GA
    Put a new TCI trans pan on during the work up on the blazer before we ordered the driveshafts. This pan holds two extra qts. so it is deeper. went to put the new shaft in today and it just did bump the pan. I ground some off the drive shaft (on the cv) so this would help but it will still be close. Any ideas!! If not I will just have to go back to a stock pan. Looks like my next post will be a TCI tranny cover for sale. ( TH350/NP205 6" lift)
  2. blazer72
    blazer72 1/2 ton status
    Apr 13, 2000
    939
    KCMO
    If your talking about the end at the 205 look to see if it get closer as it goes upas long as it does not hit at the closes point it should be fine and by not hit I mean just that not hit, remeber you would be going real slow if it did. You can take off a good bit on the cvc yoke and way.
