Drive shaft vibrations/lowering the T/case ?'s. 84 Blazer
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Ben Malinski, Jun 6, 2002.
  1. Ben Malinski
    Ben Malinski Guest
    Drive shaft vibrations/lowering the T/case ?\'s. 84 Blazer
    Installed a Rancho 4" lift kit. Front install is fine. Rear was fine until....
    Retorqued the fronts and when I started the rear, I see that the u bolts are slanted. The top of the bolts is pointed at 11 o'clock. Turn the axle so the cover was pointed verticle. Then reset everything and retorqued the bolts. I also reversed the spacer / block for the rears. The tapered end is facing rearward. My thinking was that maybe this contributed to the vibration. I did lower the T/case. Rancho makes a spacer kit. I just used angle iron 3/4 of an inch and lowered it. Still vibrations so I added another 1/2 inch and still vibrations. Added another 1/2 inch. No difference. Can't add no more or the distributor will hit the firewall. Any ideas? Suggestions? The angle of the driveshaft should be what? 30 degrees? I tried eyeballing a stock Blazer, same year, and compared the angle to mine and it looks close. Does it matter which way the spacer/blocks face? How can I make sure the drive shaft is at whatever degree it should be? Guesstamate?
    I did e-mail Rancho and still no response.
    Thanks!
  2. bee32
    bee32 1/2 ton status
    Aug 6, 2001
    401
    Virginia Beach Va.
    Re: Drive shaft vibrations/lowering the T/case ?\'s. 84 Blazer
    With a four inch lift your t-case should only be about an inch down. The blocks should angle to the rear bringing the diff yoke up towards the t-case. That is how mine is done hope it works. I am not sure of the angle but 30 sounds right. I would do a search on here about that. I know I read it in a post not too long ago.
  3. Ben Malinski
    Ben Malinski Guest
    Thanks!
    When you say angle to the rear, the smaller end pointed to the rear?
  4. bee32
    Aug 6, 2001
    401
    Virginia Beach Va.
    The taller side of the block is to the rear. I know alot of people that actualy cut the blocks and re-weld them to where they are flat instead angeled to get rid of vibrations. That might help too.
  5. Ben Malinski
    Ben Malinski Guest
    Thanks!
    But what about the slanted u bolts? No problem? It's normal?
  6. bee32
    Aug 6, 2001
    401
    Virginia Beach Va.
    I have never heard of that. If ya could take a pic of it I might be able to spot the problem there. Maybe someone else has heard of that. Sorry I can't help out more with that.
