Drive shaft Yoke
Discussion in 'The Garage' started by NUBIENLOC76, Apr 14, 2006.
  1. NUBIENLOC76
    NUBIENLOC76 Newbie
    Apr 16, 2005
    4
    ST.LOUIS MO.
    I have a 89 k-5 blazer yesterday the U-joints gave and the drive shaft dropped from the transfer case on the highway the yoke and the drive shaft are gone. Is the housing around the yoke pretty easy to replace?when the housing is taken off dose it slide right out?
  2. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    Are you talking about the pinion yoke, or the yoke on the end of the shaft?
    Sounds like the pinon yoke you're talking about. There should be a nut holding it on to the end of the pinion. Take off the nut, and slide the damaged yoke off of the end of the pinion.
  3. Masiony
    Masiony 1/2 ton status
    Sep 2, 2005
    729
    Springfield, OR
    well, he should have a 208 w/ slip yoke. sounds like he lost the whole driveline. but not a clue what end he is talking about. next time try punctuation.
