Drive Shaft ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blazer_87, Apr 24, 2004.
  1. blazer_87
    blazer_87 Registered Member
    Oct 1, 2001
    72
    Section, Alabama
    I am trying to get to the rear main on my 87 K5, i am gonna pull the tranny and tc back enough to get to it, how in the world do i get the drive shafts out. And any help on replacing the main would be great also
    /forums/images/graemlins/1zhelp.gif
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    There are 4 bolts that hold the flange of the driveshaft to the transfer case. There are also 4 bolts that hold the lower ujoint to the pinion on the axle. Remove those 8 bolts and it comes out.
    Harley
  3. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    Not to be a smart ass or anything, but you can't figure out how to remove a driveshaft, but you CAN remove a transmission and replace a rear main seal? /forums/images/graemlins/dunno.gif
  4. blazer_87
    Oct 1, 2001
    72
    Section, Alabama
    Ok, This is the first time I have dealt with a 4wd. I removed and replaced trannys on 2wd. Thanks Hossbaby. I am fairly new to 4wds. Thanks for not being a smartass.
