Drive Shaft ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by HispanicPanic, Apr 2, 2001.
  1. HispanicPanic
    HispanicPanic 1/2 ton status
    Mar 21, 2001
    351
    El Paso, Texas
    ok im going 6 inches in rear to even out my jimmy so will i have to extend my driveshaft or not cuz i have a 4inch in the rear now and my driveshaft is already pulled out a bit thanx guys/gals
    NOT ALL HISPANICS DRIVE LOW RIDERS :-) <A target="_blank" HREF=http://jimjim.coloradok5.com>http://jimjim.coloradok5.com</A>
  2. HispanicPanic
    Mar 21, 2001
    351
    El Paso, Texas
    someone's gotta have a six inch lift anybody
  3. 4GUNZ4X4Z
    4GUNZ4X4Z 1/2 ton status
    Aug 10, 2000
    3,459
    Mustang, Oklahoma
    When my brother and I lifted his K5 6" we didnt do a darn thing to his rear driveshaft and its still cooking no busted u-joints (that I can remember) and hasn't come apart on the rocks.
    <font color=blue>Professional <font color=red>JEEP EATER</font color=red> it's a population control thing.</font color=blue>[​IMG]
  4. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    Usually a 6" lift requires about 2 extra inches on the shaft.
    1987 Chevy K5 Blazer- 350 TBI
  5. Emmettology 101
    May 9, 2000
    8,126
    FL
    I did about 5inches inthe rear and didn't lengthen my rear shaft, but I blew two joints in 2 years, so I think I am going to go ahead and get it lengthened an inch or two..
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; <A target="_blank" HREF=http://emmett.coloradok5.com>http://emmett.coloradok5.com</A>
    " Ah.. Hong Kong, home of shiny green suit!"
  6. SAVAGE1
    SAVAGE1 1/2 ton status
    May 22, 2000
    1,104
    BAY AREA, CA
    I went up 6 inches just last week. I dropped the T case and that's it. So far no problems on road but I'll do some wheelin on Sun. I'm picking up a custom shaft from a buddy as soon as he takes it out of his Jimmy. The splines on my shaft are stickin out from the yoke a bit.. bout 2 inches. I'll let you know if anything happens but I'd go with a custom shaft eventually.
    Rod
  7. LittleJimmy
    LittleJimmy 1/2 ton status
    Feb 16, 2001
    220
    Channahon IL
    I would say yes, you will need a new drive shaft. If i were you I would go with a cv drive shaft. They aren't cheap but it will last a long time and you will not keep dropping the drive shaft. And it will get rid of the vibration at high speeds like highwat driving. Later LittleJimmy....
  8. Wheels
    Wheels 1/2 ton status
    Aug 18, 2000
    638
    I went 4" and had the drive shaft lengthened 1 3/4" to get rid of a small vibration that was killing u-joints. Depends on what shape the slip joint is in. If there is any play in the joint, have it re-worked.
  9. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    I have 5.5" of lift in the back, 4" springs & 1.5" blocks with a stock legenth driveshaft. I did lower the transfercase when I added the blocks, though. That minimizes the change.
    Jim '80 GMC
    Freedom First!
    <A target="_blank" HREF=http://www.bigjbear.coloradok5.com>http://www.bigjbear.coloradok5.com</A>
