Drive shaft ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BlaznRebel, Sep 6, 2002.
  1. BlaznRebel
    BlaznRebel 1/2 ton status
    Sep 1, 2002
    115
    Louisiana,Baton Rouge
    /forums/images/icons/confused.gif I have an 86 K5 i am putting together the motor this weekend 388 and have a 6" lift to install immedieatly after the motor swap is complete.Also am going to 36" swampers on 15x10 inch wheels. My question is this, will i also have to get new driveshafts cut or will the origional shafts work and also while i'm at it do i need to extend my brake lines mostly just play in the mud with a little creek crossing involved. Any help on this matter would be greatly appreciated.
    Thnx in advanve
  2. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    The drive shafts are a maybe, you won't definately know until you put it together, but there are a lot of variables that determine this. The bake and differential vent lines need to be extended with the 6" lift.
  3. denver75k5
    denver75k5 1/2 ton status
    May 15, 2001
    1,017
    Somewhere In The Woods
    On my 74 I had to do both front & rear Drive shafts,& Brake lines.
  4. 76_Cheyenne
    76_Cheyenne 1/2 ton status
    Jan 23, 2002
    285
    Missoula, Montana
    Brake lines for sure, they are going to be strecthed once the 6"lift is on. Driveshafts most likely, but probably could get away with it for a while.
