Drive shafts
Discussion in 'The Garage' started by SRAJASON, Oct 1, 2005.
  1. SRAJASON
    SRAJASON Registered Member
    Sep 25, 2005
    5
    Travis afb
    With a 6' suspension lift on a 91 k-5, Am i going to have to lengthen the drive shafts?
  2. sweetk30
    Nov 1, 2004
    25,526
    526
    horseheads , ny 14845
    6' lift ? yep if you can get the pinon angles to even come close.:wink1:
    6" lift need to lengthen them and set pinon angles to help joints out.:D
  3. SRAJASON
    Sep 25, 2005
    5
    Travis afb
    so thats a yes?, or i wont have to if i can get the pinion angles correct?
  4. sweetk30
    Nov 1, 2004
    25,526
    526
    let me clear up me stuff . need to lengthen and set pinon angles. with a blazer less problems with 4" kit. why do you want 6" kit ?
  5. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,004
    827
    Pinckney, MI
    With the front you will def need one, the rear you may need one as well depending on what type of tcase you have. I know its not the proper way but my slip yoke is just slid a little out. I will be getting a new shaft when I can afford a SYE kit.
  6. SRAJASON
    Sep 25, 2005
    5
    Travis afb
    I want to be able to clear a 36 inch tire. I just think it will be a good all around look. Now is it cheaper to lengthen them or just buy some CV type ones?
  7. sweetk30
    Nov 1, 2004
    25,526
    526
    4" lift and 3" body will clear 38" tires with tinny fender trim . just a idea for ya.
  8. jekquistk5
    Jan 18, 2004
    11,004
    827
    Pinckney, MI
    Go with the 4" I wish I did, or if you can wait 4 months I'll sell you my 6" fronts when I do the 52, 56 swap.. lol
  9. SRAJASON
    Sep 25, 2005
    5
    Travis afb
    so the 4 inch will clear the 35s no problem? the truck is in mint condition , so i dont really want to cut fenders.
  10. sweetk30
    Nov 1, 2004
    25,526
    526
    4" 35 no wheeling or fender contact. best to do 4" and 3" body if you dont want problems. and you will have room for bigger later.
  11. SRAJASON
    Sep 25, 2005
    5
    Travis afb
    Thats the reason i want to just got ahead with the 6 inch and get it out of the way, and a 36 sounds like a perfect size. I just want it to look proportional, not all squaty like it does now.
  12. sweetk30
    Nov 1, 2004
    25,526
    526
    do some searching as this has been coverd and will have some good points with some pics. and look at actual tire size specs. you will find most 36" tires are closer to 35" tires. hear is a friends blazer with 4" fronts and blocks for 6" kit in rear all with 3" body lift and 37" tires on 10" wide rims. good luck and you have found the best site for blazers. :D
