Drive Shafts
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 80K5, Sep 24, 2001.
  1. 80K5
    80K5 1/2 ton status
    Jun 5, 2001
    100
    Would it be possible to leave stock drive shafts on for a bit with a 6 inch lift as long as i didn't wheel it?
    Stuck? Isn't that a bird!
    Steve
  2. hammer
    hammer 1/2 ton status
    Aug 29, 2001
    449
    Binghamton N.Y.
    probilly no cuz first time you slam on the brakes the d-shaft will fall out. How much is still in the transfer?
  3. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    Well try to drop the t-case and see what happens... might (chances are it will) vibe like crazy and not work because the angles are still goofy or the shafts are too short. Just remember the more you drop it for the rear shaft angles the worse the front angle becomes. Plus if you run crazy angles you'll blow u-jounts like crazy... and hey maybe even drop a shaft on the highway going 65mph which would suck big time... call up Jess and High Angle Drivelines and see about getting some made up..... what's the point if in having a Blazer with a t-case anyhow if you don't even plan on wheeling it or ever using the t-case?
    GOD BLESS AMERICA!!!
    <>< PSALMS 23 ><>
    <a target="_blank" href=http://www.chevycagal.homestead.com/steph.html>Steph's Webpage</a>
  4. 80K5
    80K5 1/2 ton status
    Jun 5, 2001
    100
    Well the only reason i was wondering if I could get away with that is so that my truck will be sitting for a less amount of time but i guess it doesn't really matter if I wait more time because i only bought the thing to wheel with anyway
    Steve
