drive shafts
Discussion in 'The Garage' started by 91k5NC, Jul 30, 2002.
  1. 91k5NC
    91k5NC 1/2 ton status
    Jul 12, 2002
    206
    Durham Nc
    will a drive shaft out of a 8" lifted k5 fit in my 4" lifted k5 to correct the vibration.
  2. trailblazer87
    trailblazer87 1/2 ton status
    Jun 11, 2002
    707
    Madera, CA
    Measure them both and if they are close (within 1/2") then use it. Unless it has larger u-joints or a CV joint in it I don't think you will see a benefit. Have you tried lowering your t-case, this has helped my vibration problem. You will also need to make sure that the driveline has a slip yoke on it with the right diameter and spline count.
  3. 91k5NC
    Jul 12, 2002
    206
    Durham Nc
    thanks for the info. /forums/images/icons/confused.gif what is a slip yoke. don't know much about axels
  4. trailblazer87
    Jun 11, 2002
    707
    Madera, CA
    Slip yoke is the shaft that slips into your transfer case. If the donor driveline does not haveone, but has a slip shaft in the middle of the driveline it would not work without a kit called a slip yoke eliminator kit, you have to open up your t-case to install it.
    Your best off lowering your t-case and getting some pinion angle shims for the rear spring perches. If you want a new driveline I would get one with 1450 series spicer u-joints, I have them in mine and they seem to hold up pretty well.
  5. drivelineman
    drivelineman 1/2 ton status
    Aug 23, 2000
    707
    it will be a bit too long if it really fit the 8" lifted truck right- Jess
  6. 91k5NC
    Jul 12, 2002
    206
    Durham Nc
    thanks alot for the info, i will probely have blocks for a little while will they put the angle on the axel it needs.
