Drive Too Far Forward in Metric Starter?
Discussion in '1982-Present GM Diesel' started by uglytruk, Jun 25, 2006.
  1. uglytruk
    uglytruk 1/2 ton status
    Oct 24, 2004
    1,329
    IN A JUNKYARD, UNDER A TRUCK*N E Rust Belt
    I bought this metric starter from a local shop, and the drive wouldn't disengage the flywheel. So I brought it back to the small shop I bought it from, and he claims to have opened it and moved the shift fork to the proper location in the drive, (it was behind drive). Still Doesn't look right to me. I have it posing next to a regular starter for some reference.
    What do youz guyz think? :eek1:
  2. azblazor
    May 5, 2001
    1,953
    Arizona, Phoenix area
    The bottom pictures look pretty similiar as far as the gear stick out. Is that what you are asking? The nose cone itself looks shorter to me though.
  3. 1BadK-30
    1BadK-30 1/2 ton status
    Feb 6, 2005
    817
    Phoenix, Arizona
    sry to hijack your thread but im having trouble with my starter and one of yours it would work for me
    which one is this circled and is it for a 350? and if so where did you get it? autozone keeps giving me one that wont grab onto the flywheel and yours looks like it would work. it looks like it sticks out some ways but could be the angle
  4. uglytruk
    Oct 24, 2004
    1,329
    Hi-jack? Hell no, blast away!
    These are for DEEZELS, they are very similar, but prob won't fit small block. Much longer body, maybe different nose? You may have a starter for a different size flywheel. (Chev offered two?) I thunk the diff is starter bolts. Some are accross on one and diag on the other??? Thoughts???PS, How'd you draw the line 'round the starter? NEATO!
    These are not the best pix due to angle. The issue is simply that the drive (gear) is too far out on the shaft. I'll take some more pix...
  5. 1BadK-30
    Feb 6, 2005
    817
    Phoenix, Arizona
    ahh man i was really hopping that it would fit for my motor so i could solve this problem of it knocking and being so darn loud.
  6. uglytruk
    Oct 24, 2004
    1,329
    Here are a few more small block vs deezel starters
    Pay attention to the alignment of the bolts. Much older ones had the bolts opposite as opposed to diagonal. the SB and deezel have the same bolt spacing. so the nose is very similar, if not identical. I didn't measure the distance from the flange to the shaft on different noses, but I would guess it may be diff because Chev offered two diff flywheel sizes. But I know no more. sorry... :crazy:
  7. 1BadK-30
    Feb 6, 2005
    817
    Phoenix, Arizona
    thanks a bunch, i guess im going to have to get autozone to pull both sets out so i can examin and get the correct one.
    ps, i just paint shop pro and the eraser tool to circle the starter.
  8. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Are you sure you need a longer nose?
    Do you have a 168 teeth flywheel or 153?
    That is the only difference chevy had with starters for a small block.
    They say auto V/s manual, I always swaped those around.
    Shimming is another issue, you might need to shim your starter to make it work.
    I had one truck that took me weeks to get it to engage.
  9. 1BadK-30
    Feb 6, 2005
    817
    Phoenix, Arizona
    not sure on the teeth on the flywheel but its a 1982 stock 305 flywheel., we have never had to shim it before, but autozone insist we do it.
  10. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    Did you tell them it's a 305?
    You most probably have a 153 teeth.
    You will need a 9teeth pinion on you starter, I will ask my friend for the part number, it took him a few trys with Autozone to finally get the right one.
    As for shims, each starter case is different, some will have a stamp on them saying how much to shim.
    I had a starter with shims on my diesel burb, and now I got a gear reduction starter and on the case is stamped, do not shim
  11. uglytruk
    Oct 24, 2004
    1,329
    Most deezel starters are cast "do not shim", even the old style. IMO the shims just tweak the meshing. Too tight and it'll "screech" after the engine starts. really tight and it'l screech while it's cranking. Not a pretty sound!. Or not dis-engage the flywheel when you let go of the key. I've heard plenty of starters, gas & deezel, that are obviously missing the shims, and it sorta' sounds like a loose fanbelt, just more mechanical.
    Hard to imagine you're having this prob. The 305/350 is the most common engine, unless someone's changed something. Where's the starter/nose that wuz working on it?
  12. BKinzey
    BKinzey 1/2 ton status
    Jan 13, 2006
    3,145
    Hollywierd, CA
    Uhhhhhh? Will this help?:confused::confused: As I'm not sure of the problem:(
    My 1986 GMC Unit Repair Manual states:
    Pinion Clearance Check
    Can't be adjusted but should be checked
    1 Disconnect the motor field connector from the solenoid & insulate
    2 Connect a battery from the Solenoid Switch Terminal to the Solenoid Frame
    3 MOMENTARILY flash a jumper from the Solenoid Motor Terminal to the Solenoid Frame. This will shift the pinion into cranking position and it will remain until the battery is disconnected.
    4 Push the Pinion back towards the Communtator to eliminate slack.
    5 Measure the distance. Should be between .3mm to 3.6mm or .01" to .14"
    That covers the 5MT, 10MT and 27MT. Your new one is a 28MT (??) and I suppose it should be the same right?
  13. uglytruk
    Oct 24, 2004
    1,329
    I guess you're not clear on my prob. The manual describes ejecting the drive by energizing the solenoid. Lots of sentences to describe hitting the little screw with 12 volts!
    My issue is that the metric unit is improperly assembled. The drive is halfway out. And the shop says he fixed it. Lots of wasted labor to install it just to check... anf BTW, pinion can be adjusted. heat and bend the shift fork. Crude, bet it's a Cheby... Now if only my guy had put the fork in the right place...
