Drive train noise/vibration
Discussion in 'The Garage' started by Alumbaugh, Jan 6, 2005.
  1. Alumbaugh
    Alumbaugh Registered Member
    Dec 24, 2004
    32
    Spring Creek, NV
    I'm getting a rumble and a vibration when I'm doing over 45 in a no torque condition (not accelerating or decelerating, no load in the drive train). On straight and level it doesn't happen until you slow down, but if you slow hard it is quiet. U joints seem tight and I really can't find any play so far. Any common problems that might do this? Bearings maybe (if so, which one(s))?
    Stock 91 Blazer
    Bruce Alumbaugh
    Spring Creek, NV
    '91 Blazer
  2. jwglover
    jwglover Registered Member
    Jun 2, 2003
    88
    most likely you have some ring and pinion problems
  3. 82K5_6.5L
    82K5_6.5L 1/2 ton status
    Dec 4, 2002
    439
    Tucson, Az
    sounds like something that happene to me like last week.. truck was doing the same type of thing, turned out to be a simple rear u-joint on the d-shaft. i replaced it, and it was fine! its the little things that can make a huge difference.. :D
  4. zeroz400
    zeroz400 1/2 ton status
    May 30, 2004
    410
    Libertyville, IL
    Did you just lift the truck? If you have a vibration on deaccell then your pinion should be shimmed up.
    Later
  5. Alumbaugh
    Dec 24, 2004
    32
    Spring Creek, NV
    I haven't lifted it, but I just bought it less than a month ago. Doesn't appear to be lifted, but could have small one. What I need to do is crawl under it right after I finish driving it as it seems to do it after it has warmed up (10 minutes or so of driving). It's a noise/vibration I haven't felt in anything before and I ca't tell for sure where it is coming from.
