Driveline angels wrong?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TXsizeK5, Jan 10, 2002.
  1. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    At idle my steering wheel slightly vibrates and when i take off my manual tranny shifter kinda jiggles. Is this my driveline angle?? How would i go about fixing this. Thanks
    87 Custom Deluxe
    305/Sm465/ NP208
    4.56 , 35" BFG Muds, Series 40 delta flow 3" tips
    Coming Soon: Suspension Work, Eaton Posi, More Exhuast work.
  2. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,075
    486
    Grand Rapids area
    Wow, having angels in your driveline is better than the demons that most of us end up with! But really, when you say at idle, do you mean when you are not moving or when you are just starting to move from a light?
    It could be driveline angles, an unbalanced driveshaft or bad motor or tranny mounts
    <font color=green>Today's Forecast: Partly cloudy with a chance of mud</font color=green>
  3. mike_d
    mike_d Registered Member
    Jan 6, 2002
    7
    BelAir Maryland
    At an idle your steering wheel shaking is most likley form the vibration of motor
    the shifer giggilin is most likley the torque of the motor
    motor and trany are bolted to the frame via rubber mounts which vibrate, twist, and shake
    whatch your shifter while your driving down the road and you will probably see it moving, espessally when going over bumps
    its all normal stuff
    oh s**t I think I ran over a Honda.
    84 k5 blazer 6" lift 35" baja claws
  4. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    at idle your driveline is not rotating so i dont think that is the cause of your vibration. could be engine timing
    beligerence doesn't justify intelligence.
    <font color=blue>wheelers hate posers.</font color=blue>
    <font color=red>79k15/400/700r4/205/38.5</font color=red>
