Driveline angle problems
Discussion in 'The Garage' started by blazer_boy03, Jan 25, 2004.
  1. blazer_boy03
    blazer_boy03 Registered Member
    Nov 2, 2003
    17
    Bellefonte Pa
    Just put a 4" suspension lift on a 85 GMC Jimmy Fullsize. The rear drive shaft is in a bind any sugestions?
  2. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    3 options I can think of..
    1) shims under the leaf packs
    2) a high angle shaft
    3) cutting the spring perches off, rotating the axle as desired and welding the perches back on
    j
  3. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    Or you can drop the x-fer case.
  4. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    doh!!! forgot about that. Still, the guys rig is lifted so I figure it might get wheeled, better to keep that stuff up nice and high. /forums/images/graemlins/wink.gif /forums/images/graemlins/laugh.gif
    j
  5. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    Driveline angles driveline schmangles, who cares. hehe. The vibration doesn't start getting too bad until your pinion points up higher than the driveshaft like mine does:
    At 72mph, you don't even have to stir kool-aid, the truck does it for you. /forums/images/graemlins/rotfl.gif
    I recommend shims. Someday I'll fix mine.
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Mine is just like that...slightly negative. No vibes for me...guess I'm lucky. I'll fix that one day.
