Driveline angle/Shim????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by K5RON, Oct 3, 2001.
  1. K5RON
    K5RON 1/2 ton status
    Apr 14, 2001
    219
    Just got a CV driveshaft and was wonderin' where I can buy 3* STEEL shims? This would give me 0* at the rear u-joint when the vehicle is at rest. Or would I be better off to have it(pinion)point a degree or two down to compensate for axle wrap?
    Ron
    '84 K5......Tree Fitty, SM465/Np205, D44/14BFF, Pro-jection! .....and of coarse no other color than Odie!
  2. K5thatShmobs
    K5thatShmobs 1/2 ton status
    Sep 27, 2001
    353
    San Luis Obispo, CA
    you can go ahead and get the driveline lined up in a straight line with the pinion. You want it straight for when youre on the freeway and such... you dont have to worry about axle wrap.. besides, when youre flexing things that much, youre probably not going too fast anyway. I ran a 6 degree on my 7" lift in the rear with a CV.. Ive flexed the hell out of my rig and never had a problem. Its smooth on the freeway too. I know what you mean with those aluminum shims.. Ive cracked some myself. The only company Ive found that makes steel ones is Tuff Country. www.tuffcountry.com. Ive had those in the rear forever, and theyve held up fine. Hope I could help.
    Chris
    San Jose, CA
    '84 K5, 7", 35x16 boggers, and a lot of fender hacking
  3. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Ron, you dont want your rear pinion angle to be "0". You want it to be 1 or 2. You will have axle wrap. Thats why you will need to have the angle at the rear to be 1 or 2 to comp for the axle wrap so that when you are driving the angle will be at zero.
    Good luck on find good shims.
    "you know... the guy with the BAD A$$ spring perches!!![​IMG]
    <a target="_blank" href=http://www.nashvillek5.freeservers.com>www.nashvillek5.freeservers.com</a>
