Driveline angle with shackle flip
Discussion in 'OffRoad Design' started by FL84K5, Jul 23, 2002.
  1. FL84K5
    FL84K5 1/2 ton status
    Aug 19, 2001
    936
    Sarasota, FL
    Do I need to use shims on the rear axle with a 4 inch shackle flip and stock rear springs? Where can I get shims?
  2. bobsurf
    bobsurf 1/2 ton status
    Jun 26, 2001
    410
    San Marcos, CA
    I believe you will need to correct that angle, but I don't know where to get those shims.
  3. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    i just put the flip on my 89 and the angle were fine, no vibes. the flip gives you some angle because the rear spring is lower but of course every truck is different. i would try it first and then get a angle finder if you are getting vibes to find the right degree shim
  4. Stephen
    Sep 15, 2000
    4,228
    142
    Carbondale Colorado
    Sapper's got the answer, you may not need the shims, give it a shot. Typically the flip sets the angle up right for a CV joint but it's not terrible for a ujointed shaft either.
