Driveline Angle
Discussion in 'The Garage' started by Bart Reid, Aug 16, 2006.
  1. Bart Reid
    Bart Reid Newbie
    Mar 31, 2006
    4
    Valley Center, CA
    I installed a 4" lift kit and need to adjust the rear drive shaft angle to reduce vibration. Are there any issues anyone knows about created by lowering the transfer case? Does it change engine angle enough to make a difference? Will the transfer case and tranny shifter linkage need to be modified? Would wedges to change rear end angle be a better choice? Any advice would be appreciated!
    1990 Blazer, 4" lift 35" tires
  2. lamberthkp
    lamberthkp SITFU Premium Member
    Jan 17, 2005
    1,468
    16
    West TN
    on a 4'' lift just lowering the transfer case should do the trick. i have a 6'' and i did that to my blazer and have no vibration. check u-joints if you still have vibration. :D
  3. bajaviking
    bajaviking 1/2 ton status
    Apr 10, 2002
    752
    Baja
    I lowered my transfer when I did my shackleflip and I have not had any issues with it but I still I think I would prefere the wedges to not loose height under the transfer.
  4. purplehavoc
    purplehavoc Registered Member
    Jul 30, 2006
    18
    ontario,canada
    Just wondering how much you dropped your t-case?
    Need to lower mine again.
  5. bajaviking
    Apr 10, 2002
    752
    Baja
    I just moved the factory spacers to go between the frame and the crossmember. I guess it's about an inch.
  6. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    It all depends on the lift you used really. If it was springs, blocks or flip.
    Have a look at HADs website. There is a link to a really useful guide on pinion angle and UJ operating angles.
    Get it wrong and at highway speeds you're in for a rattley ride!
