Driveline angles, T-Case lowering, problems
Discussion in 'The Garage' started by DaveCowley, May 20, 2002.
  1. DaveCowley
    DaveCowley 1/2 ton status
    Feb 18, 2002
    196
    Provo, UT, USA
    I currently have a 4 inch lift with a 2 inch t-case lowering kit 208 T-Case, with an ORD shackle flip which makes the pinion on the 14 bolt point almost straight up at the T-Case and I am just wondering if any of you have a similar setup without the lowering kit and do you have any problems with driveline vibration do to driveline angles.
  2. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    hope this helps clear up some things.
    <a target="_blank" href=http://www.4x4wire.com/tech/pinionangle/>http://www.4x4wire.com/tech/pinionangle/</a>
    arq.
  3. Mreetz
    Mreetz 1/2 ton status
    Jun 26, 2001
    1,282
    Subs of Denver, Colorado
    I had problems with the 4" until I lowered the T-case. No problems since then.
