Driveline Angles ***Update***
Discussion in 'The Garage' started by dammit32, Jan 4, 2004.
  1. dammit32
    dammit32 1/2 ton status
    Jul 20, 2002
    365
    Maine
    I raised my t-case back up to the stock position, ground off the spring perches on the rear axle, measured my t-case angle (4*)...concluded that the pinion angle at 2* would be perfect
    then i welded them on, installed the driveshaft and went for a ride.... the misery continues
    it seemed to shake some on load but during braking the bolts on the rear u-joint clashed with the driveshaft yoke...
    It appears to me that I exceeded the limits of the driveshaft...
    Because my K5 is a DD I needed to recover it so that it was at least usable so I dropped the t-case down 2" and it vibrates but I can use it
    HELP
  2. dammit32
    Jul 20, 2002
    365
    Maine
    After some thought and a run out to the K5 with a protractor... with the tcase lowered the driveshaft is at 20* so the working angle of the ujoint is incredible....
    HELP
  3. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    dammit!!!havent seen you post in FOREVER..anyways.. i have a thought.. maybe you could make some spacers to drop the t-case, with a little more angle towards the rear..so the rear of the t-case sits just slightly lower than the front?
  4. dammit32
    Jul 20, 2002
    365
    Maine
    well it looks like i'll opt for the cv shaft as soon as the budget allows ... but i have to drive it to get around til then
    So I think I will try to drop it an additional 2" at the tcase(for a total of 4")...I may have to pull the front driveshaft until I get a CV because with it dropped 2" the driveshaft is laying on my Y-pipe(4" will probly separate the donuts at the manifold)...after dropping the tcase 4" I should be able to acheive some descent angles with shims on the rear axle.
    another scenerio i was pondering for a temp fix was to remove the shackle in my shackle flip which would lower the rear and make the K5 look silly but I would still retain 4WD and get good angle.
    just some thoughts...
  5. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    @ 4" of tcase drop, i think your distributor is going to hit the firewall, maybe not with your smaller TBI cap
  6. jwglover
    jwglover Registered Member
    Jun 2, 2003
    88
    I RUN 8'' LIFT AND THE 14BOLT IS TURN UP AND THE T CASE IS
    DROPPED 2 IN, I RUN A 400/205 WITH A SLIP YOKE ON THE T-CASE
    AND DONT HAVE ANY VIBRATION,
    IT HAS BEEN IN ABOUT 7 YEARS, LOTS OF WHEELING AND ABOUT 75 K ON THIS SET UP, NO PROBLEMS,
    BUT WITHOUT THE 2 '' DROP ON TCASE IT DOES HAVE A BAD VIBRATION
  7. dammit32
    Jul 20, 2002
    365
    Maine
    so you think my driveshaft is tweaked?
    the shaft in the tcase seems firm and the rear 14b has about 20k on it and feels firm as well
