Driveline angles
Discussion in 'OffRoad Design' started by JWSLightning, Jul 7, 2002.
  1. JWSLightning
    JWSLightning Newbie
    Jul 7, 2002
    3
    Maryland
    I'm planning a 4 inch lift for my '87 K5. My initial thought was that with 4 inches drivline angles would not be an issue but some others that will be involved in the project have voiced concerns. Can anyone tell if driveline angles will be an issue with a 4 inch life?
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> They may be fine, and may not be. There is so much variation in Blazers that no two are ever exactly the same. You just have to do the lift and see how it turns out, then adjust from there. Generally any lift over 4" needs some angle adjustment, but there are exceptions. I lifted my K10 6" and the angles were perfect after putting on the lift, but that is uncommon. </font color>
  3. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    At the 4" lift level things can be good or bad. Mine ran fine with a 3" lift and 33's but I had 3.73 gears. I swapped to 4.56's and all of a sudden I couldn't run over 65. That's just one of the variables.
    I would highly recommend leaving room in the budget for a CV jointed driveshaft for the rear. You can try to match the angles up but if your combination does not allow it, or your tolerance level for ujoint wear and noise doesn't allow it, go to a CV joint and your problems become fewer. No matter what, more angle on the joints is hard on them, regardless of the type, CV or no CV.
  4. bobsurf
    bobsurf 1/2 ton status
    Jun 26, 2001
    410
    San Marcos, CA
    Just trying to suck up some info for when I'm ready to do mine. As I understand it, he basically has 3 options for correcting that angle:
    1. CV jointed driveshaft
    2. Rotate the rearend and move spring perches
    3. Rotate the rearend and use shims
    Anything I'm missing?
    Sorry Stephen, this should probably be in a general CK5 forum.
  5. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    nope /forums/images/icons/grin.gif
  6. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    And lowering the transfer case /forums/images/icons/wink.gif
  7. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    Basically, everyone so far is correct. You need to match the angles or your driveshafts. The lower your gears, the worse your driveline problems will be. In my opinion, do the lift, then worry about the angles......try to make them equal. Don't use a kit to lower your Tcase if you go that route. Use some solid plate steel if you have to. Take your time and do it right the first time.
  8. Mreetz
    Mreetz 1/2 ton status
    Jun 26, 2001
    1,282
    Subs of Denver, Colorado
    Any recommended place in Denver to get a CV drive shaft? /forums/images/icons/smirk.gif
  9. i_4x4
    i_4x4 1/2 ton status
    Feb 20, 2000
    359
    Brighton, Colorado. USA
    I've used
    Englewood Driveshaft (for my 1350 rear shaft). I don't know their #.
    Drive Line Service of Denver (for my front shaft).303-287-5538
    I was very pleased w/ the work of both shops. Hope this helps.
    Later Ed
  10. Mreetz
    Jun 26, 2001
    1,282
    Thanks!
    I'll chase down the #.
  11. 79Beast
    Dec 9, 2001
    1,155
    Georgia
    I'm from GA, so I'm really not familiar with Colorado. I would suggest talking to Oscar at Arizona Driveline. I have had VERY good experiences dealing with him. I'm not sure on the phone number, but its in the back of FourWheeler and Peterson's 4Wheel and Offroad. Look for the ad that says www.drivelinesolutions.com
  12. Mreetz
    Jun 26, 2001
    1,282
    Thanks, I contacted them. Looks like some pretty stout work comin outta their shop there!
