Driveline angles
Discussion in 'OffRoad Design' started by Ryan Melton, Dec 4, 2002.
  1. Ryan Melton
    Ryan Melton Registered Member
    Dec 15, 2000
    61
    Texas
    Stephen,
    Got the Doubler in and am measuring for shafts and was curious as to how steep an angle I can run the pinions on my axles. I've heard about 20 degrees max. I know its likely I'll need to rotate knuckles.
    Specifically the 14 Bolt rear. I've shortened my W.B. to about 125" and was considering running a two piece shaft in the rear with the pinion pointed up high as possible.
    What would be the steepest the 14 Bolt can run and still get adequate pinion bearing lubrication on a trail only truck vs. a sometimes street driven truck?
    Thanks,
    Ryan
  2. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    I'm not sure what to tell you on that one, I'm running about 18 or so on my 14FF with no apparent problems. I suspect there are plenty of 14FF's running about this angle since I have a pretty common drivetrain and lift height. I'm not sure where to send you for more info on this, I'm sure somebody has a better answer than I do.
    Larry Dagon has the 2 piece driveshaft with CV setup and it works well for him. Certainly easier on driveshafts than a 1 piece job.
