Driveline clunk noise
Discussion in 'The Garage' started by MOLON LABE, Jul 19, 2005.
  1. MOLON LABE
    MOLON LABE Registered Member
    Apr 15, 2005
    28
    Arizona
    In 1985 I special ordered a 1 ton 4x4 just the way I wanted it. Not a dually, 454, 4-56 gears, all the bells and whistles.
    It was a great truck except it had the "factory clunk" from day one. When putting it in gear, brake pedal pressed, it made a loud metallic "clunk" like the u-joints were gone but it wasn't them. I took it to our two local dealers, both said tough luck, it's a normal condition, nothing was wrong. I complained up the chain of command but no luck.
    I sold the truck a few years later.
    Fast forward to now. Last year I bought a creampuff 1990 suburban 1500 4x4, 5.7 with only 30,000 original miles and it has the same noise.
    I have since heard that packing grease somewhere in the driveline would fix it for a while, is this true and how and where do I do it ??
    Also, is there a permenant fix for this ?
    Thanks in advance.
  2. Brocky
    Brocky 1/2 ton status
    May 22, 2005
    1,170
    St.John's Newfoundland, Canada
    Have you took a notice to how much backlash you have in the rearend. Don't know if this could be your problem.
  3. MOLON LABE
    Apr 15, 2005
    28
    Arizona
    I'll look into the backlash issue but best I can tell it's happening up around the yoke and tailshaft housing.
    Anyone else have any ideas ?
  4. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,030
    858
    Pinckney, MI
    Check your Tranny mount, as well as your motor mounts. When you put it into gear even with the brake on if the mount is bad it will move and go clank. My mount looked fine, untill I loosened it up and got a good look at it. good luck
  5. gone huntin
    gone huntin 1/2 ton status Premium Member
    Oct 25, 2004
    1,706
    Coldwater, MS
    I have the exact same truck and mine USED to do this. I finally found that dielectric grease (very thick) on the slip yoke splines worked extremely well. Since then I have installed a H.A.D. CV equipped driveshaft and no longer have the problem.
  6. MOLON LABE
    Apr 15, 2005
    28
    Arizona
    This is the "fix" I have heard about. Putting grease on the splines at the slip yoke. Thats where my noise is coming from.
    What's the procedure for this operation and is there a prefered brand or type of grease that works best ?
    How long does this work before it clunks again ?
    The HAD CV joint shaft, where can I get info on it ?
    Also, I have heard that GM has a nickel plated yoke that fixes this problem on newer models. Is there a fix similar for the older trucks ?
  7. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    depending on which it is, its also possible that there is also slop inside the transfer case.
  8. gone huntin
    Oct 25, 2004
    1,706
    Coldwater, MS
    H.A.D. I didn't have anymore clunks after I used the dielectric grease, but due to a vibration, I installed the cv shaft a month later. Personally, I used some Motorcraft dielectric grease just because that's what I had. I used a big flatblade screwdriver and spread the grease out inside the slip yoke.
