driveline clunk ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by RAY, Apr 3, 2004.
  1. RAY
    RAY 1/2 ton status Premium Member
    Jul 4, 2000
    281
    Austin, Texas
    A have heard a clunk lately when I let off the gas. Does this sound like a slip yoke going bad, u joint or ring and pinion? It kinda feels like it is coming from somewhere around the t-case. It alson clunks when I shift from reverse to drive.
    Thanks,
    Ray
  2. vegas76k5
    vegas76k5 Registered Member
    Apr 20, 2003
    31
    Las Vegas, NV
    Mine was doing the same thing. I replaced both my rear u-joints and it solved it. Check them for play.
  3. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,084
    486
    Grand Rapids area
    Once U-joints are checked out, I would look at the differential. Could be a lot of wear in the spider gears or ring and pinion. Pretty common, actually.
  4. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    You might also want to double check that your crossmember and mounting bolts are tight.....
  5. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    1. Check the U-joints.
    2. Check the tranny crossmember bolts
    3. Check tranny mount...is it the stock mushy rubber one?
    4. Last resort...check the U-bolt tightness...
  6. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    If you are talking about the pick up, also check out if it has one, most pick ups do, the center carrier bearing located on the middle crossmember. Those wear out and will bounce around when you let off the gas or hit the gas real hard.
  7. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    a 203 TC can also cause some slop...
