Driveline E-brake or Caddy calipers poll and questions???
Discussion in 'The Garage' started by Desert Rat, Oct 9, 2004.
  1. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    Currently I have a rear disk conversion on my Corp14ff rear. I got Caddy calipers from TSM and have them mounted up. The trick has been deciding how to hook up the E-brake. I am toying with the idea of ditching the rear E-brake and going with a High Angle Driveline TC mounted driveline E-brake instead. So, poll to follow but a question: Can I just leave the TSM calipers intact without swapping in the non-E-Brake calipers or will they need constant tension on the arms to keep the pads close to the rotor?
  2. rodzzilla
    rodzzilla 1/2 ton status
    953
    Grinnell, IA
    I voted for ditching the caddy calipers. Figured you could sell them to defray some of the cost of the HAD Kit. I am going to go that route so I don't have to worry about snagging the cables.
  3. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    If I ever do disc brakes id go with the Caddy calipers. The only thing is I heard they were a pain to adjust the e brake and you ll have a low pedal.
  4. jwduke
    jwduke 1/2 ton status
    Aug 25, 2001
    721
    Ice Cream Capital of the World, IA.
    I started with caddy calipers, and gave up on them because no one can come up with a replacement, for the stock levers. They are next to impossible to find.
  5. COCHEV
    COCHEV 1/2 ton status
    Jul 9, 2002
    4,055
    Washougal WA
    i think when i do mine, i am going to use a line lock /forums/images/graemlins/thumb.gif
    on an episode of trucks they were putting disks on a furd 9" and the rotor had a set of drum brakes that fit inside it for the parking brake. it was cool as hell. now if someone could come up with a set up like that for 14 bolts, that would be the sheeeeaaat
  6. TWISTEDJACK
    TWISTEDJACK 1/2 ton status GMOTM Winner
    Jul 24, 2002
    882
    Boise, ID
    Why not just hook up a line lock????? cheap and effective.
  7. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Can I see the pics of how you hooked up the e-brake??
  8. Desert Rat
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    Here is the thread that we had going previously that has his pics in it: Look here
  9. Desert Rat
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    Did you ever consider swapping in a different pedal mechanism? Or I wonder if one could modify a center console lever type taken from another car that would work. By the way, got a response back from HAD. $420 for their setup. That is a spanking. I've also had some folks e-mail me with stories of how their HAD didn't work, but also read several that are very happy with the setup. /forums/images/graemlins/dunno.gif
  10. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    lol that was my old thread /forums/images/graemlins/thumb.gif
  11. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Thats what I thought it was when I got one. Someone was selling one in the for sale forums for something like $250. I know it didnt cost anyhitng close to $250.
  12. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I have the HAD e-brake. It will hold on about as steep of a hill as the tires will hold on. Hooking it up just took a small piece of angle iron with 2 holes drilled in it and one bolt. Having the HAD driveshaft is something that I wanted to do anyways so it wasn't that bad.
  13. jwduke
    Aug 25, 2001
    721
    Someone should look at the e-brake pedel out of a late model Monte Carlo. I bolts up where our pedel does, and you push it down, it sets the e-brake like ours does. Monte Carlos use rear disc brakes.
