Driveline mount question.
Discussion in 'OffRoad Design' started by sageman, Jun 9, 2003.
  1. sageman
    sageman Registered Member
    Sep 27, 2002
    40
    Calgary, Alberta, Canada.
    With or without a double t-case, is it ok to mix a poly t-case mount with rubber engine mounts?
  2. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    i dont see why not. there is so much distance between the mounts the poly would help in the big picture, but i dont see how it could adversly affect the engine mounts. may make the polly mounts runn out faster than they normaly would. but i doubt you would notice it.
    Grant
  3. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    We generally recommend a stiffer motor mount than transfer case mounts but it really becomes a problem when you have a lot of power and traction. The problem is if you have a really stiff transfer case mount, the motor will twist against it and break stuff.
