DRIVELINE NOISE!!! Need Help ASAP!!
Discussion in 'The Garage' started by BXwildshot, Dec 1, 2003.
  1. BXwildshot
    BXwildshot Registered Member
    Sep 17, 2001
    97
    Bronx , NY
    I have an 89 Suburban with the original 10 bolts awaiting a 14 bolt/D60 transplant. Yesterday I was cruising down the street when I noticed the truck was making a clanging/knocking sound which to me was coming from the pass. side front. The sound would change pitch and get louder when I hit the brakes. Anyway I got it home and proceeded to take off both pass. side tires to check the brakes , NOTHING. Took the pass AUTO hub off, NOTHING. Took driveshaft off to check u-joint and CV, NOTHING. Finally took off rear diff. cover to see if I lost a tooth somewhere but once again, NOTHING. The rear is I believe a GOV-LOCK or whtever was stock posi in 89 but I don't see anything obviously wrong with it thru' visual inspection. The only other things I can figure is that its coming from the drivers side drum brake or the transfer case BUT the noise DOESN'T occur when in REVERSE or if the rear tires are OFF the ground. Sorry about all the reading but I wanted to explain this well. Anybody have any ideas?
    Eric
  2. BXwildshot
    Sep 17, 2001
    97
    Bronx , NY
  3. justhorsinaround
    justhorsinaround 3/4 ton status
    Sep 16, 2003
    6,798
    Northerish Phoenix, Az
    I would look at the rear drum like you said. Maybe a spring busted up in there. The other one would maybe be you have a warped rotor. That would make those kinda noises as well. Maybe some one else can come up with some better ideas. Good luck to ya.
    Allan
  4. justhorsinaround
    Sep 16, 2003
    6,798
    Dangit, where was my head. Is that thing IFS?? If so check your half shafts. That's a better thought cuz on account I had an 89 Z-71 that made those same noises and it was a worn out half shaft. Again, good luck to ya.
    Allan
  5. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    89 suburban is still solid axle...
    anyways...did you check for tightness of the front wheel bearings? if they are loose and allowing the rotor and hub assy to walk on the spindle..possible loose caliper, or broken caliper bolt, maybe broken pad? did you make sure that the rear shoes havent seperated ie: the lining from the backing plate?
  6. BXwildshot
    Sep 17, 2001
    97
    Bronx , NY
    Thanks for the replies guys but I think I found it. I think it the rear outside axle bearing that crapped out.Eric
