Driveline problem??
Discussion in 'The Garage' started by PhoenixZorn, Apr 7, 2005.
  1. PhoenixZorn
    PhoenixZorn 1/2 ton status
    Mar 17, 2005
    1,734
    West Allis, WI
    When I let the clutch out nice and slow, I can feel it grab the tranny and it sort of "clicks", which is slightly annoying... the big problem is when I am going for quick accelleration, I shift, pop the clutch, and I feel the tranny and transfer case slam into the bottom of the truck... or something is hitting it... anyone have any experience with this?? What did you do to fix it? All support brackets, bars, and bolts are in place, and it didn't do it with the 327... only now with the new clutch and 350.
  2. PhoenixZorn
    Mar 17, 2005
    1,734
    West Allis, WI
    come on guys... I need tips here... no one has even looked at this yet...
  3. JNygard
    JNygard Registered Member
    Mar 19, 2003
    45
    Nampa ID
    Sounds like a broken motor mount or tranny mount. Thats the first thing I would be looking for.
  4. PhoenixZorn
    Mar 17, 2005
    1,734
    West Allis, WI
    Fixable or would I need to replace something if that's the case?
  5. PhoenixZorn
    Mar 17, 2005
    1,734
    West Allis, WI
    Called the shop, head guy said sounds like my 380 torque ripped the tranny off it's mounts... the whole stick jumps when I accellerate, so he judged that to be the problem... said as long as I go easy on it and don't tow anything, I should be ok until my 500 mile oil change, at which time, he'll replace the mounts... I hope he reinforces the crap out of it...
  6. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    They're pretty easy to replace yourself, and you can get nice poly ones that would be good and firm. Just take out the two big bolts going up into the tranny/t-case adapter from the bottom of the crossmember. Then you can jack up the tranny a little bit, pull out the old mounts and put in the new ones. If you get some energy suspension ones or something, they'll probably even come with illustrated instructions. I'd hate to think about paying someone to do something that's fairly simple.
  7. PhoenixZorn
    Mar 17, 2005
    1,734
    West Allis, WI
    hmm... got a place to buy them?? I can't search from work, but I can click the links... =) If I can do it myself, i'd rather, but I thought there was heavy welding involved, and I don't have a welder...
  8. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    you can get the stock rubber mount at any auto parts store for about $15. the poly mount costs usually around $75. the stock rubber one will take alot of abuse, but won't last as long. the stock ones usually last for 15+ years in a stock truck.
  9. JNygard
    Mar 19, 2003
    45
    Nampa ID
    Summit Racing
    Here is the link to Summit Racing for the Poly tranny mounts. Just bolt in, no welding involved.
  10. PhoenixZorn
    Mar 17, 2005
    1,734
    West Allis, WI
    Just called the local AutoZone, and they said they have an OE aftermarket replacement tranny mount for 28.99... I asked if it was rubber or poly, and he said it's very hard rubber, and feels like it could be poly... in your experiences, does AutoZone actually have anything worth buying, or should I wait the 2-3 days for shipping from Summit and pay an extra $20.00?
  11. PhoenixZorn
    Mar 17, 2005
    1,734
    West Allis, WI
    Also, should I buy the transfer case torque mount while I'm at it and fix it before it breaks?
  12. PhoenixZorn
    Mar 17, 2005
    1,734
    West Allis, WI
    .... ttt
  13. karmannghia
    karmannghia Registered Member
    Mar 28, 2005
    5
    Stockton, Ca.
    universals
    :what: I have had my truck for 2-1/2 years now and I have gone throught 6 universals on my rear drive line. In the last year I have only the highway and boat pulling thing. No 4 wheelen and no drag dacing. Again last night I looked at my truck and the rear universal on the rear drive line is broken. What am I doind or is this regular?? Help this is starting to piss me off.
    HELP
    LGB :mad: :confused:
  14. JNygard
    Mar 19, 2003
    45
    Nampa ID
    If it were me I would order the Poly if your in no hurry. Might as well start beefing it up if your putting alot of torque down.
  15. JNygard
    Mar 19, 2003
    45
    Nampa ID
    karmannghia, Need a little more info about your truck, such as lift, body style.
    Most likely u-joint are failing due to drive line out of balance, or excessive angle on the u-joints.
  16. dyeager535
    26,982
    191
    Running a mixture of poly and rubber engine/tranny mounts is generally not recommended...people have broken the adapters while running a mismatched setup.
  17. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    I thought you weren't suppose to change to poly tranny mounts without also changing to poly motor mounts. Something about having a more rigid mount on one end and a softer mount on the other created stresses and broke something.
  18. PhoenixZorn
    Mar 17, 2005
    1,734
    West Allis, WI
    just bought the OE replacement tranny mount from AutoZone... I'll be puting it on tonight if I have time before dark... otherwise, tomorrow morning will have to do. Any suggestions other than what was already said about removing old mount, jacking up tranny, and attaching new mount? Any idea if the bolts require a certain amount of torque, or can I use a standard socket and not worry about it coming apart?
  19. karmannghia
    Mar 28, 2005
    5
    Stockton, Ca.
    right now my truck is just stock, The only thing that I have are 32" BFG Mudders. I put a NEW drive line in then drove it like little miss grandma. Nothing more that my mom's saturn goes through. I amgoing to be going to the drive line shop tomorrow and get it fixed, just trying to get a little heads up or tell him what would be better then what I have now. I need my truck runnin soundly ASAP.
    LGB
  20. PhoenixZorn
    Mar 17, 2005
    1,734
    West Allis, WI
    So, am I safe with a broken tranny mount for 500 miles as long as I don't do anything stupid like try to race?? I mean, regular granny style shifting, rolling along at a decent pace, I only felt the thump when I really gave it the heavy foot... I just don't want my torque to rip the whole tranny out of the truck.
