Driveline problems if I drop my T-case?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MilpitasK5, May 1, 2002.
  1. MilpitasK5
    MilpitasK5 1/2 ton status
    Nov 13, 2001
    889
    Milpitas, Ca.
    I'm planning on dropping my T-case to see if it will help my vibes while on the freeway.
    I had my front and rear drivelines extended to accomadate my 3 inch lift (front) and 3.5 inch lift (rear). Will I have any problems after dropping the T-case?
    Thanks,
  2. SAVAGE1
    SAVAGE1 1/2 ton status
    May 22, 2000
    1,104
    BAY AREA, CA
    When you drop your Tcase, it'll make the slip yoke of the driveshaft go farther in to the Tcase. Just make sure it leaves enough room to slip in and out so it doesn't bottom out when your springs compress. How much of the yoke is showing right now?
  3. MilpitasK5
    Nov 13, 2001
    889
    Milpitas, Ca.
    I think there's 'bout 1 or 2 inches. Then I should have some room when I do my shackle flip and zero rates, right?
