driveline question
Discussion in 'The Garage' started by blazerpro79, Sep 24, 2005.
  1. blazerpro79
    blazerpro79 1/2 ton status
    Jan 4, 2005
    528
    Simi Valley, CA
    i have about 5" of lift in the back right now, and im going to put about 4" more (its a cruiser, not a wheeler). i know from stock you can 99% of the time put a 4" lift with no problems... i was wondering, since i did have my driveshaft lengthened for the 5" about a year a ago... if i added 4" more, would it be safe.
    so i guess my question can be summed up as "is the rule that you can go 4" over what your drivetrain is designed for?"
  2. koldsimer
    koldsimer 1/2 ton status GMOTM Winner
    Jan 10, 2005
    1,480
    texas
    I doubt that it will work for you. If you never wheel it, maybe. The problem you will have is that the operating angles of your u-joints will be a bit too much. You should just get a cv shaft and be done with it. I'm running a conventional shaft with a 1410 at the case and a 1350 at the diff with about 7 inches of lift. I wouldn't go any higher personally with a non-cv shaft.
  3. bigbadchev84
    bigbadchev84 1/2 ton status
    May 17, 2004
    2,191
    Hermiston, Oregon
    i was fine with mine, 4" springs 4" blocks and a zerorate on mine with 39.5s and never had any vibration or length issues with mine
