Driveline question???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Blazin Ed, Apr 9, 2002.
  1. Blazin Ed
    Blazin Ed Registered Member
    Mar 29, 2002
    92
    Seattle
    Put a 4" lift on the K5... Should the driveline be lengthened to where the shaft was originally located on the output of the transfer case? If not, how do I measure what the ideal length should be? Someone said the new travel might affect exactly how long it should be... Wanna make sure I do this right before I spend the $$$... Thanks!
  2. René
    René 1/2 ton status
    Mar 14, 2002
    208
    Michelbach, Germany
    With 4” lift kits further modifications are not necessary. However a steering arm would be not bad.
  3. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    It seems that all rigs are different.
    Most drop the t-case 1" to correct any drive shift vibes.
    Most likely that is all you will have to do.
  4. Big_B_Murphy
    Big_B_Murphy 1/2 ton status
    Dec 28, 2001
    159
    New Stanton, PA
    It is likely that you will need to lenghten your driveshafts. Take a measurement from the yoke on the driveshaft to the yoke on the axle. Then take this measurement along with the one for the other shaft to a shop that can re-tube your shafts. Should be easy to find one in the yellow pages, or talk to some guys in your area who have had it done to find out who does good work. The best advertising is word of mouth. It is best to get both shafts balanced after they are re-tubed as you don't want any vibrations.
