Driveline slipping Need Help
Discussion in 'The Garage' started by cegusman, Jul 8, 2002.
  1. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    1st my driveline consits of: 700r4/208/14bffw/govlok
    no front driveshaft striped pinion
    When in 2high or 4high some thing seems to too be slipping only from a dead stop or cornering, it is really bad if I get on the gas hard. But in 4low it does not slip at all, no matter how i drive. I have test it on and off road and it only slips in high. /forums/images/icons/confused.gif Need help /forums/images/icons/confused.gif
  2. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    TTT
    Is there anyway the 208 could be the problem?
  3. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Anybody, I need help
  4. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    Sounds like a clutch (if you have a manual tranny) or bands/clutches (if you have an automatic....update I now see you have a 700r4). The added leverage the drivetrain has against the tranny in hi gear is enough to make it slip but not in low. Also could be misadjusted linkage as the body may be moving vs. the frame, or your TV cable is out of adjustement. Hope you figure it out and keep us posted.
