driveline spacer
Discussion in 'The Garage' started by ryaninc, Apr 29, 2007.
  1. ryaninc
    ryaninc Registered Member
    Feb 13, 2005
    45
    Salem, OR
    anyone know where to get a driveline spacer to go between a NP208 and my front shaft? superlift makes one for about $55. Hoping to find one for cheaper.
    Thanks Ryan
  2. bbck5on37s
    bbck5on37s 1/2 ton status
    Jan 3, 2007
    543
    Denver Colorado
    look in the colorado section. lake2004 has a spacer that i belive will work.
  3. bbck5on37s
    Jan 3, 2007
    543
    Denver Colorado
  4. mo
    mo 1/2 ton status
    Jun 29, 2004
    542
    Folsom, CA
    can you use this on a rear cv shaft? is this safe for the rear? what about strength?
    thanks
  5. ryaninc
    Feb 13, 2005
    45
    Salem, OR
    wont let me contact
    thanks I found it. That is what I need and I would buy it but it wont let me message him or even post a reply (because Im not a member?) why can I post here but not there? you totaly dont have to do this but if you want to you could let him know im interested, maybe show him this Post, since I cant seem to post on his thread. Thanks if you dont want to thats cool
    Thanks again Ryan Happy Wheeling
  6. mo
    mo 1/2 ton status
    Jun 29, 2004
    542
    Folsom, CA
    i responded to his post letting him know you were interested...
    you're pry right about not being able to post cause you're not a member, but being you just saved $25 on that spacer, you could use it for a membership :)
  7. lak2004
    lak2004 1/2 ton status
    Aug 31, 2006
    3,809
    Durango, CO
    Sorry but the spacer had been spoken for. Why are you needing it? My front was hitting on the xmember so thats why i got it. But I put some washers in instead because the spacer was a PITA to get in. The bolt holes wouldnt line up right. Maybe try a new mount too. Let me know and I can probably get you a deal on a new one. My buddy works at 4 wheel parts.
  8. ryaninc
    Feb 13, 2005
    45
    Salem, OR
    driveline to short, or maybe not enough travel?
    I did a 52" spring swap to the front and I lengthend the D-line an in or so. But at full droop and flex it falls apart (to short). I thought a spacer might be the way to go (cheaper). I dont really have much rub issues on the crossmember. I have taken the grinder to it though.
    your thoughts?
    thanks Ryan
  9. Mudstud
    Mudstud 1/2 ton status
    May 29, 2001
    1,472
    Memphis, TN
    Man if you are separating youe shaft now a 1" spacer isn't going to cure that. Even if the shaft stays together at flex it'll only be by a hair. The problem that will result (when the suspension relaxes) will be binding in the slip yoke and it'll transfer that pressure to your t-case and likely break your t-case adaptor and or the top left part of your tranny housing (where it bolts to the adaptor) A cheap solution is a square front shaft or limit your travel.
  10. lak2004
    Aug 31, 2006
    3,809
    Durango, CO
    Still need a spacer?
