driveline vibe
Discussion in 'The Garage' started by Pow06er, Aug 29, 2005.
  1. Pow06er
    Pow06er 1/2 ton status
    Apr 9, 2005
    188
    ne, ohio
    i need to get a better angle finder but it looks to me like the slip yoke angle is 5 degrees down angle and the pinion is 10 degrees up angle
    its like after i lowerd the case the block is overcorrecting
    it vibed without the case lowered and it vibes with it
    except with the case lowered the grinding noise i was worried about is gone
    i dunno its liveable but its frustrating to know that it could be smoother
    im about to just take it to this shop i know the guy hes got a lifted k5 and another lifted truck to see wat he says
    dropping the case definately helped out the vibe but i get ti from about 0-50 with it being worse at about 35-40 while im crusing
    its totally none existent while coasting
  2. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    fill out your profile so people know whatcha got.(lift size/brand/etc.) it's alot easier to give advise when u know the stats of the truck are. BTW i know how u feel. i've been battling the driveline vibes ever since i lifted my truck. im about ready to go with a CV rear shaft. that may be what you need.
  3. gone huntin
    gone huntin 1/2 ton status Premium Member
    Oct 25, 2004
    1,706
    Coldwater, MS
    That's what I finally had to do. Give Jess a call or email at H.A.D.
  4. Pow06er
    Apr 9, 2005
    188
    ne, ohio
    its a '88 with 4" Tuff country springs and 0rate up front and 4" blocks out back i think there might be an old aal back there too
