Driveline Vibes............I know again
Discussion in 'The Garage' started by MTBLAZER89, Jul 26, 2004.
  1. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    OK OK I know this gets beat to death. I have a slight driveline vibe only below 35 MPH maintaining speed. If I accelerate or let off and coast it goes away it is also not present at all above 35. Will just one inch of lift cause this (0-rate) or could it be driveshaft is pulled out of the slip yoke a bit too much?? I have whatever shims came with a 4" Superlift spring, and a zero rate. This only came about with the zero-rates and a tranny swap. U-joints are both brand new. Any advice what to change/check first?
  2. MTBLAZER89
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    /forums/images/graemlins/dunno.gif
  3. js4x4
    js4x4 1/2 ton status
    Jul 17, 2004
    798
    San Diego, CA
    Huh...mine vibes a bit under 35 or coasting, goes away accelerating or over 35 also. I think i need to change the u-joints ? anyway, similiar problem i've developed...son of a...
