driveline vibes
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bigblue, Jan 20, 2001.
  1. bigblue
    bigblue 1/2 ton status
    Dec 6, 2000
    658
    southern california
    ok, it has been an expensive year for bigblue but i am still optomistic. I had a 6 inch lift with national spring installed. then i had a 1 ton 1350 CV style driveshaft put on ( thinking there would be no problems with my driveshaft ). I have vibes between 15 and 25 mph and i just know it is there at high speed. I already have a 4 degree shim in the rear. what should i do? what is the maximum shim i can put on the rear diff and is it easy, or expensive to drop the t-case? thanks for any feedback.
    baja surf nazi
  2. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>If you dont have the case dropped, thats your problem. It's easy, just move those round spacers from under the crossmember to above it (between the frame and the crossmember). Thats all there is to it, its free.</font color=blue>
    <font color=blue>pavement queen with shinny paint job and car tires</font color=blue>
  3. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    if you do it your self the t-case drop is free. just take the bolts off the cross member and put the spacers between the frame and cross member instead of on top of the frame this will give you a 1in t-case drop
    s.smith 77blazer lookin 4 mud
  4. KENBARBOUR
    KENBARBOUR Registered Member
    Jan 14, 2001
    54
    You want the driveshaft to be inline with the rear pinion with a CV rear driveshaft. A few degrees down is ok because it will rotate up on acceleration. T-case drop also a great idea.
    I got a cheap magnetic angle finder from sears to check mine.
  5. drivelineman
    drivelineman 1/2 ton status
    Aug 23, 2000
    707
    hey you guys know there is a 1350 c/v joint that fits your 205 t case right? this makes your vibs go away- give me a ring- 530-872-5725 jesse
