Driveline vibration -- Pinion angle?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by K5thatShmobs, Dec 1, 2002.
  1. K5thatShmobs
    K5thatShmobs 1/2 ton status
    Sep 27, 2001
    353
    San Luis Obispo, CA
    Can you get driveline vibration from the pinion angle being too straight? Theres no bend where my pinion meets the rear shaft because of spring settle. I know youre supposed to have at least a little angle. Mine doesnt... anyone know if this can cause vibration at low speeds?
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> The important peice of info missing in your post is whether you have a CV shaft or a regular one. </font color>
  3. pilgrim
    pilgrim 1/2 ton status
    Sep 10, 2001
    247
    new hampshire
    I have the same problem with vibes out back, and just read last night that both pinion's should be parallel to each other. but with the exception of the rear being 1 degree DOWN so as to compensate for axle rap.
    My rear pinion is inline with the driveshaft, and the t-case is be no means at a high angle (suburban). but i heard that if you don't have a cv joint that both joints need to be at the same angle in order to cancel each other out..
    also i heard sears carrys a cheap angle gauge. which is my next stop since i hate driveing around in front wheel drive /forums/images/graemlins/grin.gif
  4. K5thatShmobs
    Sep 27, 2001
    353
    San Luis Obispo, CA
    Sorry, I have a CV at the T-Case end.
  5. sosamantx
    sosamantx 1/2 ton status
    Aug 14, 2000
    393
    somewhere in Texas
    i'd say it's possible, but not for sure.
    "also i heard sears carrys a cheap angle gauge."&lt;-- i didn't know this, if you find out, can you post the part #?? i need to get one for another vehicle, but it is about $80-150 or so, if i remember correctly.
  6. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Yes, with a CV you should have the pinion pointed down about 2 degrees, when you apply throttle, it will pull back up straight. double check your pinion U-Joint for wear just the same.
  7. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Just to clarify on Borrego's post, the pinion should be down 2 degrees from being directly inline with the driveshaft, not 2 degrees down from flat. Just wanted to make it perfectly clear. /forums/images/graemlins/thumb.gif </font color>
  8. Grim-Reaper
    7,385
    Atlanta
    Hmmm I think I heard that somewhere before.
