Driveline woes...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by scott87, Nov 29, 2001.
  1. scott87
    scott87 Registered Member
    Feb 7, 2001
    39
    basalt, colorado
    I think I know the answer to this, but just wanted to get some more input. On my 87K5 I put in a 4" shackle flip and a 1" ORD block. Vibrations were horrible. I measured for a CV Shaft. Installed that today. Better, but vibrations still there. I checked the slope of the driveshaft and compared it to the slope of the end yoke at the diff. There is a difference of about 4-5 degrees. Didn't check that before i got the CV shaft. Anyhow, is this angle difference the main source of the vibration? I feel silly for asking about this, but just want to cover some bases before getting too frustrated.... Any opinioins?
    scott
  2. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    So you have the CV joint dl AND vibration? I think I do also.
    I thought with the CV you were guarrenteed no vibes.....?
    Dave
    Horn Broken... Watch For Finger.
    <a target="_blank" href=http://coloradok5.com/gallery/Daves-Pics>http://coloradok5.com/gallery/Daves-Pics</a>
  3. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    You did point the pinion on the axle at the tcase right? It should only be a couple of degrees down but relatively straight at the pinion.
    I started with nothing and I still have most of that left! - <a target="_blank" href=http://www.echobit.com:81/k5/> Pictures</a>
  4. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Borrego is right. The pinion must be almost directly in line with the drive shaft or a CV shaft will not work right. A few (1 or 2) degrees down on the pinion is preferred because axle wrap when accelerating will tilt it up by that much.
    Russ
    85 K30 CUCV, 350 TBI, TH400, 205, D60/C14, 4.56 Locked
    Some day: 4" lift, 44" tires, massive cutting, shorter wb and rear overhang.
  5. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    I'll ask the dumb question since it is only my 504,639,756th.... How do you adjust for this correct angle?
    Dave
  6. kpanza
    kpanza 1/2 ton status
    Dec 8, 2000
    1,579
    Lake Forest, Orange County, California
    You have to point the pinion right at the t-case output! It should actually be DOWN by one degree for the optimum situation (torque pulls it up one degree, so you compensate by going down one degree!)
    If you didn't do this, that is probably the source of the vibes...and if you have a slip yoke t-case some people think it will give vibes worse than the fixed yoke. I have the 4" shackle flip also and have shimmed the rear end to be almost equal to the case (no cv shaft for me) angle, and I still have vibes at higher speeds...
  7. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    To go from a standard shaft to a CV you generally must cut off and realign the spring mounts.
    Russ
  8. scott87
    Feb 7, 2001
    39
    basalt, colorado
    how is this done, i.e., pointing the pinion at the t-case? do you mean shimming the pinion? the driveshaft sits at about 20 degrees slope. The pinion is about 16 degrees. So, shim it up to 20 degrees?
  9. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Thanks BadDog. That might mean relocating my shock mounts also if the rotation needed is grat enough.
    I'll go take a pic and see what y'all think.
    Dave
  10. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Not good pics but it loks like I am in that 2 degree range. But I dont have radian eyeballs..... I will be lifting to level this weekend so I will check it out.
    http://coloradok5.com/gallery/album35/aal
    Dave
  11. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Sorry to get off subject, but nice sliders. Did you make them? If not where did you get them? Just wonderin. Thanks
    My Chevy isn't broken, its just out of gas.
  12. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Thanks.
    Bent and Twisted in Chico Ca
    (530)342-3003
    Mike Ladd
    Mike builds AWESOME roll cages and accesories.
    Dave
  13. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Hard to tell at that angle but it does look like the pinion needs to be raised. You need to use one of those angle finders to see exactly what needs to be done.
    Russ
  14. JIM88K5
    JIM88K5 1/2 ton status
    Apr 27, 2001
    1,384
    Vancouver, Wa
    Wow Scott,
    I have the same set up and I just got my CV shaft and installed
    it today but with better results. My pinion angle is a little low
    but I think it's acceptable. It does not vibrate at all. YAHOOO....
    It was not an out of control vibe before but it was not right.
    My transfer case has the lowering spacers but I want to take those out. Then I will have to shim the pinion up a few degrees. Boy am I stoked about that drive-shaft !!!
    88 5.7 5in lift 35"procomp at's
    700-208-456-3in exh w/flowlowder 10 bolts & some ORD stuff
