driveline
Discussion in 'The Garage' started by chvymudin3388, Jul 11, 2006.
  1. chvymudin3388
    chvymudin3388 1/2 ton status
    Mar 3, 2005
    374
    orange grove ,tx
    i have execsive drive line slack. when i get out of the gas and its over about 3000 r.p.m.s it takes a lil while not alot of time but it goes cluck and starts slowing down
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    What Tranny?
    Transfercase?
    Detroit in the rear axle?
    Are the u-joints in good shape?
  3. chvymudin3388
    Mar 3, 2005
    374
    orange grove ,tx
    its a 700 r-4 with a 208 transfer and my u joints have no apparent play when put in neutral and twisting the drive shaft. and nope just a gov-bomb in the rear. it seemed to got worse when i had to romp my truck cause i was stuck in a ditch going straight with the wheels cut left. but i think its always beent his bad im just making it seem worse but ethier way theres alot of slack
  4. readymix
    May 30, 2004
    6,706
    26
    Set the parking brake on a flat level surface. then put the trany in neutral. Get under the truck and twist the driveshaft back and forth.
    You might be able too see where the slop is if it is in a u-joint or the rear axle.
    If the rear axle then pull the diff cover and check it out.
  5. chvymudin3388
    Mar 3, 2005
    374
    orange grove ,tx
    i know its not the rear end i was just in the rear end and everything looked fine im thinking its etheir where the tranny hooks up to the transfer or the transfer to drive shaft or the ujoints
  6. sweetk30
    Nov 1, 2004
    25,536
    533
    horseheads , ny 14845
    that style tranny tcase is male tranny female tcase setup. not a lot of room for play like the old 205 tcases couplers.
  7. chvymudin3388
    Mar 3, 2005
    374
    orange grove ,tx
    so could it be the splines on my drive line? ill recheck the joints but i really dont think its them
  8. chvymudin3388
    Mar 3, 2005
    374
    orange grove ,tx
    well it looks like its the pinnion to yoke the yoke moves and the nut in the middle takes awhile not a long time but noticeable and there is very little transfer to driveshaft
  9. drivelineman
    drivelineman 1/2 ton status
    Aug 23, 2000
    707
    Is this the only complaint? what is it hrting? does it vibrate? Jess
  10. chvymudin3388
    Mar 3, 2005
    374
    orange grove ,tx
    it kinda seems like it could be hard on my drive train.
  11. Avery4jc
    Avery4jc 1 ton status Premium Member GMOTM Winner
    Oct 24, 2005
    10,760
    75
    Fresno, Ca.
    Mine has some play, I don't worry about it though. I keep an eye on things and it doesn't vibrate so I don't see the need to worry about it. With so many connections you can expect a little of play/slack in it. Not a lot but a little.
    -Avery
