Drivelineman or anyone who knows
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mybeast, Oct 17, 2000.
  1. mybeast
    mybeast Registered Member
    Oct 10, 2000
    95
    Simi Valley, Ca.
    I'm treating my 79 jimmy to a full driveline & suspension face lift, and i'm trying to get everything together so I can do it in 2 or 3 days. I'm swaping out the 10 & 12 bolt for a 14ff and dana 60 with 8 or 10 inches of lift, and 39.5" tires.. Is there a way to get the drive shafts done before I do the work, or will I have to take measurements. If it can be done a head of time ballpark figure, how much? opitions? (my truck is going to be huge!!)
    When all else fails MASH the skinny pedal!
  2. Zepplin
    Zepplin 1/2 ton status
    Aug 29, 2000
    920
    Bay City, MI 48706
    Your safest bet is to install everything and then take the measurements. This will give you the correct lengths for the driveshafts and angles.
    Dazed and Confused in a 74 Blazer
    Zeppelin
  3. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    You're in luck. Since you are swapping to a 14 bolt and Dana 60 front, these diffs are larger and have more pinion "stick out" (for lack of a better term). I think you'll find that you need NO driveshaft mods in terms of length to accomodate the swap with that much lift. You will, however, require a special u joint that accomodates your 1/2 ton driveshaft and the 14 bolt's yoke. These are available at better driveline shops, just tell them the application. The front dana 60 yoke size is THE SAME as what you have now (1310 series). Good luck!
    ken
  4. mybeast
    Oct 10, 2000
    95
    Simi Valley, Ca.
    Ken,
    Thanks man.[​IMG] Thats great I plan on going to 1 ton shafts sooner or later, but for now I can put that money some where else.
  5. Jeff427
    Jeff427 1/2 ton status
    May 22, 2000
    1,186
    Gladwin, MI
    You had it almost right, you just needed to type out "image" completely in the brackets.
    Jeff427
    <font color=red>Mud Dog Off Road Club</font color=red>
    http://muddogoffroad.coloradok5.com
  6. 1HIHUM
    1HIHUM 1/2 ton status
    Jun 28, 2000
    366
    Fremont, CA
    Don't spend the money just yet! Your ride may be different, but when I put in an eight inch lift on my 72, I came up about two inches short on both drive shafts. I went to a local shop, and it only took a few minutes whip them up. These shafts were both brand new though. they cost about $250 each. The rear was up graded to 1350 joints for good measure. Good luck.
  7. BigBurban
    BigBurban 1/2 ton status
    Jun 14, 2000
    237
    AZ
    Just in case you go this route... The NAPA part # for this u-joint is 447. They go for around $28.
    <font color=red>~BigBurban</font color=red>
    http://www.geocities.com/crash607
  8. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    Or, your friendly neighborhood driveline shop, Neapco part # (I forget) for about $15. NAPA is SUCH a rip-off!!!
    ken
  9. mybeast
    Oct 10, 2000
    95
    Simi Valley, Ca.
    Thanks everyone I guess the smart thing to do would be to set the money aside and what till the lift and swap are done. Then again I've been called alot of thing, but smart doesn't come up to often.
